Old 27-08-2006, 04:11 PM   #1 (permalink)
rajwansh2003's Avatar
Smile Login screen of 2000 in XP help!
My login screen of Xp has changed to 2000. How can i get back XP login screen back? please help me out friends!!
Anupam
rajwansh2003 is offline
Old 27-08-2006, 04:51 PM   #2 (permalink)
I see right through you.
Sykora's Avatar
Default Re: Login screen of 2000 in XP help!
Go to Control Panel > Users and Accounts > Use Welcome Screen - Check it.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 27-08-2006, 05:27 PM   #3 (permalink)
SE><IE
Posts: n/a
If the welcome screen has disappeared then you can do the above trick.
In case the login screen looks like 2000 style (win 2k written all over) then goto windows\system32 replace the logonui.exe file with http://rapidshare.de/files/30932549/logonui.zip.html one. log off and back. You're done!
- by gohan89
