Old 13-08-2006, 10:30 PM   #1 (permalink)
Default Help Needed in XP
Hi all..
I use Windows XP on my Laptop. Since beginning I've faced problem in shutting down. While shutting down it stays on the "Windows is Shutting Down" screen endlessly and eventually I have to press the Power button to shut it. I would appreciate your help or comments on what is wrong and what needs to be done.
Thanks
harmads is offline
Old 13-08-2006, 10:43 PM   #2 (permalink)
I see right through you.
Sykora's Avatar
Default Re: Help Needed in XP
That's not very descriptive, harmads . Anyway I'll see what I can do. I read once that one of the reasons Windows may take a long time to shutdown is because it's deleting the pagefile. The solution to this is a registry hack.
Trying doing what tip#2 on this page says, possibly using digit's fastrack to registry editing for help : http://reviews.cnet.com/4520-10165_7-5554402-1.html
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 13-08-2006, 10:55 PM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
i faced this problem in 98 .... change the copy of the OS u r using (another copy of XP) .... that solved the problem for me ... possible in ur case also....
http://beingmanan.com
iMav is offline
Old 13-08-2006, 11:16 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
Which Anti virus you use, is it Avast.
My cousin had same kind of probs. with his HP Compaq laptop. that AV slowed down his LapTop.
If you use Avast then experiment by Shutting down the Avast first & then ur PC. If your PC finally shuts down, then Avast is your problem maker , Un-install that Anti Virus & go for AVG or NOD32....
& do a regular check-up of Fragmentation of files.(Defragmenter).
__
s18000rpm is online now
Old 13-08-2006, 11:21 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Paste these lines in notepad:
REGEDIT4
[HKEY_CURRENT_USER\Control Panel\Desktop]
"AutoEndTasks"="1"
"HungAppTimeout"="1000"
"WaitToKillAppTimeout"="2000"
"LowLevelHooksTimeout"="1000"
Save the file with any name but extension should be .REG, now run the file. It'll ask for confirmation, select YES and then OK. It should help U.
http://www.AskVG.com/
Vishal Gupta is offline
Old 13-08-2006, 11:42 PM   #6 (permalink)
String Phreak
mediator's Avatar
Disable "Clear Pagefile at shutdown"!
mediator is offline
Old 14-08-2006, 04:54 PM   #7 (permalink)
Thankyou guys. I will tryout some of the suggestions posted and will let you know the results ..
harmads is offline
