Old 13-08-2006, 08:01 AM   #1 (permalink)
Default PRO -E install help
i have pro e wildfire version, but i dont have lan connection in my home so it is impossible to use it , will the soft require and lan card only or there should be any server connection, as it is used by me in my home its not possible for my to have any lan connection but i can use a ethernet card installin only in my system. so please is ther any way to use it with out lan
www.mechroyals.host.sk
web site for all mechanical engineer's.. come in share us
steelwin is offline
Old 13-08-2006, 08:07 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: PRO -E install help
What is Pro-e ? I tried googling but got only a few guides/books here and there.
This thread makes me think its some repartitioner
please suggest
Harsh J
www.harshj.com
QwertyManiac is offline
Old 13-08-2006, 08:45 AM   #3 (permalink)
^ Pro E is a design and stress analysis / simulation software... amazing for chasis design....
@steelwin: which version of wildfire do you have? there are 1,2 and 3 now! i have used wildfire 1 on a standalone computer with no LAN.. but i have heard that wildfire 2 and 3 do require LAN to run.. if there is a workaround.. i wanna know too !
kikass is offline
Old 14-08-2006, 09:20 PM   #4 (permalink)
yes wildfire 2.0 requires the lan card for the host ID,
i think that the software which creates a virtual network adapter, (like the one which comes with the modem for broadband, which creates a virtual network adapter when modem is used via USB port.) should do the job, cause one of my friend told that he was able to make it work.
keep it cool
nd4spd is offline
