Old 13-08-2006, 05:44 AM   #1 (permalink)
Default how to extract and merge audio into an AVI file
i want to extract the audio from an .avi file, and then add different audio track to it, ofcourse of same length.
plz help me in doing so.
i have no clues about how to do it.
keep it cool
nd4spd is offline
Old 13-08-2006, 02:02 PM   #2 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Default Re: how to extract and merge audio into an AVI file
i think u can use a software like cool edit pro.. use the trial version and try..
its good and i often make my mobile ringtone with this software.. get a try
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 13-08-2006, 04:49 PM   #3 (permalink)
Tux Fan
shaunak's Avatar
Use virtualdub or gordion knot [search on sourceforge]
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 14-08-2006, 09:13 PM   #4 (permalink)
K i have downloaded VirtualDub, now how to do it, means how to extract audio from avi file.
keep it cool
nd4spd is offline
Old 14-08-2006, 09:53 PM   #5 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
also try vcd cutter....
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 14-08-2006, 10:52 PM   #6 (permalink)
666
solomon_paulraj's Avatar
Smile Re: how to extract and merge audio into an AVI file
use vcd cutter the download link... http://www.jiaovideo.com/download/vcdcut.exe... very useful software for ripping audio from vcd and rejoining it...
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
solomon_paulraj is offline
Old 15-08-2006, 02:47 PM   #7 (permalink)
Thanks for all your responses, it would be very helpful, if someone could describe the process of merging the audio in an avi file, using VirtualDub.
keep it cool
nd4spd is offline
Old 18-08-2006, 12:57 PM   #8 (permalink)
Download GSpot and open your .avi. See what audio codec it reports, note it down.
Assuming the audio is in mp3 format (most downloaded DivX files have mp3 audio), proceed as follows -
Open .avi in VDub. Use "File > Save Wav" option. VDub will save all audio with .wav extension. Rename the saved file using the correct extension. You may have to use "Windows Explorer > Tools > Folder Options" to show extensions of all file types. Rename "abc.wav" to "abc.mp3".
Now you have the audio file extracted and ready for editing. You can put it back (merge) into the .avi using NanDub. Now, that's another story altogether.
You should post the results of GSpot here. A screenshot of GSpot will be best. Let me know what exactly you're try to achieve so I can give more detailed responses.
Cheers,
Keith
Last edited by Keith Sebastian; 19-08-2006 at 10:56 AM. Reason: Automerged Doublepost
Keith Sebastian is offline
