Old 12-08-2006, 06:15 PM   #1 (permalink)
Default can not stand by
I have P3 800MHz Ram:320MB Hdd:40GB motherboard:810
i can see "stand by" option but it is not highlighted.
plz help.
i want to activate that option.
atul19as is offline
Old 12-08-2006, 07:34 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: can not stand by
Try to install VGA drivers from ur motherboard CD...
http://www.AskVG.com/
Vishal Gupta is offline
Old 14-08-2006, 10:56 PM   #3 (permalink)
ayush_chh's Avatar
yes that is the only reason i know....
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 10-02-2007, 01:36 PM   #4 (permalink)
Smile Re: can not stand by
the problem was there because ACPI tag in the bios under power management was disabled
i changed it to enable
& everything is fine.
atul19as is offline
