| Forum |
#1 (permalink) |
I have a PC with following config... P4 2.4 ghz intel, asrock motherboard, samsung syncmaster 793s monitor, 512 mb RAM, samsung DVD combo and a geForce 6200 "A" 128 MB graphic card. I have directX 9.0c and have the latest driver for my graphic card. Forceware ver 91.31 I cant play DVD in my system. Earlier i couldnt play any video at all but then i used Win Amp's latest version and in that i disabled the overlay function and then i can play video stored in my comp. Similarly i disabled overlay in Quicktime and it plays video but i cant get DVD playback. powerDVD doesnt play nor does Window media player 10. it stops responding. HElP me solve this problem ppl. PLZ!!! |
#5 (permalink) |
first check yr dvd at yr friends computer to check if it is at fault.
or try removing graphics card and then play a dvd.
Be like a postage stamp-stick to one thing until you get there. |
#6 (permalink) |
But if i remove my graphics card............. i cant play all the games that
i play HEEHEHEHE. like i said......... i can play video files in my pc if i disable the overlay option..... is there a way i can do that for a DVD??? Last edited by St ANGR; 12-08-2006 at 01:59 PM. Reason: Automerged Doublepost |
#9 (permalink) |
look my motherboard supports dual monitor okay.
so wat i did was selected the second monitor and then my DVD runs. nit doesnt run on graphics card only. and other media player like WMP or powerDVD doesnt play ANY video at all. the system hangs. heheheh can anybody help me with the solution???? mail me at painintheneck23@gmail.com it wud be a BIG help thanks |
#10 (permalink) |
hey buddy, u havnt installed the display drivers for your new display adapter, or else your os is not accepting it, try reinstalling it/ update it..
Hope it would help.... if u cant play only dvd's then reinstall powerdvd.... finally if al fails, ur COMBo must be damaged., if its in warranty contact the dealer he may help u.
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
