Old 11-08-2006, 08:23 PM   #1 (permalink)
Default The strange inaccessible
I have a strange problem, someone who thinks that he is so smart.. had an argue with me.. so he had done few wrong things to my system and one still not solved is in the image below
In that a folder named "MAK" gives above error(as shown in the picture) whenever I try to open, its not getting deleted not even renamed etc.. its totally something out of our control but sitting in our PC.
Any guy .. having any idea for this stuff ?
Waiting......
Ricky is offline
Old 11-08-2006, 09:11 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: The strange inaccessible
Does your account have admin priviledges? If yes, then goto folder properties->security->advanced->change owner, make it your account also check allow all in the priviledges..
kalpik is offline
Old 11-08-2006, 09:19 PM   #3 (permalink)
shashank4u's Avatar
try system restore.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 11-08-2006, 09:30 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
If the folder doesnt appear under the DIR command, google for Unlocker.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 12-08-2006, 01:25 PM   #5 (permalink)
its visible in Dir command and I am going to see about ownership issue and then will inform here.
Ricky is offline
