Old 11-08-2006, 04:19 PM   #1 (permalink)
Default win xp with sp2 integrated problem
I had a winxp pro cd. I integrated sp2 in it. Now when i use the cd key which i used to give before integrating sp2, does not work. please can you people help me by giving the solution to this problem.
can you give the cd key which will work in winxp pro sp2
reply as fast as could because i am struck now without any OS
regards devrath.n.d
And happy independence day for everyone
Devrath.N.D is offline
Old 11-08-2006, 04:24 PM   #2 (permalink)
Venom's Avatar
Default Re: win xp with sp2 integrated problem
Get an original windows
From now on we are poison to you, that's why we call ourselves, the Venom!
Venom is offline
Old 11-08-2006, 04:37 PM   #3 (permalink)
I see right through you.
Sykora's Avatar
Or if you do, already, call customer support.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 11-08-2006, 04:50 PM   #4 (permalink)
google it yaar u will find the solution for ur problem
BTW such topics r not allowed here
signature??? Let Me Think About It!!!
paul_007 is offline
Old 11-08-2006, 04:59 PM   #5 (permalink)
Google Bot
Pathik's Avatar
arey install sp1 register with ur official key then install sp2.....
or do as told above....
Pathik is offline
Old 12-08-2006, 05:46 PM   #6 (permalink)
Ben Jacob's Avatar
yes i got an eazy solutin
first u run the software downloaded from this link
http://www.yacapa.com/ftp/microsoft/XPPID.exe
in the window of XPPID enter the required product key of SP
then install and enjoy
Ben Jacob is offline
Old 12-08-2006, 09:30 PM   #7 (permalink)
Stalker's Avatar
try google....
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
