| Forum |
#1 (permalink) |
The Sexy Beast
#4 (permalink) |
Coming back to life ..
To uninstall IE7 Beta 1, Try this :
Start > Run > Appwiz.cpl <Press Enter> In the Add Remove Programs applet, Check the option that says Show updates. Now IE7 Beta 1 should be visible in the list.
Sleight of hand and twist of fate... On a bed of nails she makes me wait... And I wait without you ... With or without you .. ---- Batty = Too Busy Now !!! |
#6 (permalink) |
The problem can be solved by
Control Panel -> Add/Remove Programs -> (Check) Show Updates on top right corner -> Remove IE ! Make sure that you have clicked the 'Show Updates' checkbox. Rick www.CrazyEngineers.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
