Old 09-08-2006, 12:03 PM   #1 (permalink)
Question video conversion PROBLEMS
....ok
i bought a zen(orignal),
i got its cd's
the problem is with the video conversion...
at first when i installed everythign was fine..
thn something happened to pc and had it reinstalled...
after that videos didnt convert...
i treied reinstalling software but no avail...thn i downloaded other video convertors....like movkit,video convertor+ and another....but they all display errors....dont say what kind ... either hang up or display error....even the orignal zen software which used to work fine doesnt convert any more
my friends say my pc is jinxed....
help me pls??
soulrogue is offline
Old 10-08-2006, 12:17 PM   #2 (permalink)
JGuru's Avatar
Default Re: video conversion PROBLEMS
Looks like your PC is infected with some malicious software (Virus/Worm).
Use a good anitvirus like Norton 2006 , get the updates from the Net. And do a full
System scan. You can also try Blaze Media Pro software (www.blazemp.com).
It's an excellent software for Audio/Video conversion.
JGuru is offline
Old 14-08-2006, 05:06 PM   #3 (permalink)
oh ok thanks am trying that...ill tell u if it solves my problem...anyways thanks for helping
Old 14-08-2006, 10:42 PM   #4 (permalink)
666
solomon_paulraj's Avatar
do you have all the codecs installed needed for conversion>>??? if not install any of the codecs pack like klite or vlc codec pack...
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
solomon_paulraj is offline
