Old 23-07-2006, 11:31 AM   #1 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Question Finding J2SE 5.0 SDK
Hey guys,
Ineed the Java 2 Second Edition 5.0 Software Development Kit. I went to this site: www.java.sun.com/j2se and also here www.java.sun.com/javase/downloads/index.jsp but could not understand wat to d/load. But i d/loaded the J2SE 5.0 JDK Source code wich says this...
JDK 5.0 source code is available for those interested in exploring the details of the JDK. This includes schools, universities, companies, and individuals who want to examine the source code for personal interest or research & development. The licensing does not impose restrictions upon those who wish to work on independent open-source projects.
But wen i unzipped this, there wasa folder named install, but there was no installer. I knw im doin sumthing wrong, but tell me wat i shud be doin.
I need to learn programming on Java so please tell me wat to do, and where to d/load the appropriate s/ware.... (giv the links please.)
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 23-07-2006, 11:39 AM   #2 (permalink)
JGuru's Avatar
Default Re: Finding J2SE 5.0 SDK
@Ashu, You need to download 'JDK 5.0 Update 7' and also you need Documentation.
So download'J2SE 5.0 Documentation' also that contains the documentation for JDK.
You don't need the 'JDK 5.0 Source code' !!!!
I hope things are clear now.
JGuru is offline
Old 23-07-2006, 11:54 AM   #3 (permalink)
Question Re: Finding J2SE 5.0 SDK
@ JGuru,
Thanx for ur reply bro.. So tat means the JDK Source Code is useless (from my programming (begineer) point of view) ?? (please guide me)...
I will surely d/load the JDK 5.0 7 Update along with the J2SE 5.0 Documentation.
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 23-07-2006, 02:42 PM   #4 (permalink)
Brave_Hunt's Avatar
Probably this may help you. Visit here.
And well said, E=MC˛ And there's a light!
Brave_Hunt is offline
Old 27-07-2006, 01:04 PM   #5 (permalink)
Thumbs up Re: Finding J2SE 5.0 SDK
@ JGuru,
Thanx for ur reply bro, i have installed JDK 5.0 Update along with its documentation and now i can program adn learn with it...
@ Brave, thanx for the link..
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 28-07-2006, 12:26 AM   #6 (permalink)
aadipa's Avatar
If you are new to Java, refer to some online tutorials, there are many, even Sun have good tutorials on their site. First you should be very clear with concept of Objects.
At beginning, use notepad2 as test editor (You can use notepad too, but notepad2 gives syntax highlighting). And compile/run your code with command prompt.
When you are comfortable with coding, you should move to some IDEs like Eclipse or NetBeans. There is option to download JDK and NetBeans bundle, but don't use any IDE till you are done with core java.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 28-07-2006, 01:00 PM   #7 (permalink)
Exclamation Re: Finding J2SE 5.0 SDK
@ aadi
1.) Well i used Jcreator Lite Edition to compile the programs (as given in a tut wich i d/loaded from a site). Please tell me how can i compile using the cmd prompt. In our college (an older version) of jdk1.3 is available and we can program on it using the cmd prompt by writing the codes in notepad and saving them as <file_name>.java in the "bin" folder of jdk1.3 and compiling it in cmd prompt.
2.) But here (at my home), How can i program in the cmd prompt ?? Please suggest. Is JCreator LE (Lite Edition) perfect for writing codes or shud i be writing and compiling codes in the cmd prompt ??
3.) I want tat i shud be able to test the program on both s/wares (i.e Jcreator LE (wich i already have) and even in cmd prompt (wich i dnt knw wat to install further or wat to do at my home PC) ....
Awating replies from u techies (on Java)...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 30-07-2006, 09:34 PM   #8 (permalink)
JGuru's Avatar
Compiling JAVA programs in cmd-line:
javac <filename>.java
Running the program from cmd-line;
java <filename>
I suggest that you download & use NetBeans IDE 5.0 BlueJ Edition. It's for
guys learning JAVA & also it's very easy to use. It comes with host of great features.
You'll love using it.
Checkout the screenshot:
Get it from here:
http://edu.netbeans.org/bluej/index.html
JGuru is offline
Old 30-07-2006, 09:39 PM   #9 (permalink)
@ J
Thanx a lot bro,BTW wats the compiler or s/ware to run JAVA based programs on FC4 (LINUX OS) as i guess that the above screenshot tat u have posted is of a Java compiler in LINUX, so wats it ? Please enlighten me...
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 03-08-2006, 05:34 PM   #10 (permalink)
hi!
you can download the dk fro linux from the following url
http://java.sun.com/j2se/1.4.2/download.html
and selecting the second option of jsdk 1.4 dpwnload
on the next screen choose linux . it works on fc4 also
r@ohit
r@hit is offline
Old 04-08-2006, 08:36 PM   #11 (permalink)
@ Rohit
Thanx for the useful info bro BTW, doesnt FC4 has an in-built java compiler or any thing similar to tat??
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 05-08-2006, 01:53 AM   #12 (permalink)
18 Till I Die............
You can use either Sun JDK or GCJ and I guess there one more, blackdown or something, if I remember right.
But, IMO Sun JDK would be more preferable. It is also available for linux platform, and you can use any editor like nano, joe, kate, kwrite, gedit, vim, emacs, etc to write your code, compiling would be the same.
One more thing, install JDK in your system path. To know what it is, open your console and type
echo $PATH
http://www.bash.org/?258908
mehulved is offline
Old 05-08-2006, 02:52 AM   #13 (permalink)
deathvirus_me's Avatar
JCreator all the way ... if u think that Netbeans IDE was impressive .. then take a look at this :
Also .. this editor is totally configurable .... and u get a very Visual Studio feel ... the only backdrop is that u can't use command line arguments ... as if u'll ever need those ... though u can have a round about way ...
Also ... i think all current linux distro are bundled with jdk ...
deathvirus_me is offline
Old 05-08-2006, 10:31 AM   #14 (permalink)
@ deathvirus,
yup bro, i hv a feel of JCreator (lite and Pro) editions on my XP machine, as i hv compiled sum begineer programs on it and yup i agree to u tat it really gives a Studio feel effect of a professional (working with 3 panes..lol..). Is this Jcreator available for Linux too or will my JCreator version (running on WIN XP) can be installed on Linux??
Cheers n e-peace,......
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
- by gohan89
