Old 19-07-2006, 02:23 PM   #1 (permalink)
Default MGS 2 Graphics problem
My Computer Configuration:
Intel 915GL Motherboard
3.0 GHz Intel Pentium Dual Core Processor
512 MB DDR RAM (Kingston)
Onboard Graphics(No external Graphics Card)
I bought a legal copy of Metal Gear Solid 2: Substance. There were 8 installation cds( equivalent to 7.9 GB). The game installed fine. But when I run the game there was no graphics, only sound. I can hear the background music and even the menu clicks. But the screen is blank.
Now, heres the twist. I installed the game on my friends machine with configuration:
Intel 845 chipset
1.7 GHz Pentium
256 MB RAM (Kingston)
Onboard Graphics.
The game runs perfectly on my friends machine.
Please help me.
ironcross77 is offline
Old 19-07-2006, 07:48 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: MGS 2 Graphics problem
did you check the game website or read me,maybe your onboard doesn't have enough power.
Third Eye is online now
Old 19-07-2006, 11:11 PM   #3 (permalink)
Man, my system even runs doom 3 in 800x600 resolution with descent fps.
MGS 2 is an old game (probably the pc version was released in 2004).
Moreover the min system requirement on box says "runs perfectly on an 865 chipset".
Old 19-07-2006, 11:58 PM   #4 (permalink)
thunderbird.117
Posts: n/a
Iam having the same problem like you. I paid 2500 for Metal Gear Solid. The day it was released and 1500RS for MGS 2 last year. The game did not work. Anyways iam not intrested in MGS series any more.
MGS :- GOP is the last of the series.
Old 20-07-2006, 05:45 PM   #5 (permalink)
Thank god I bought it much cheaper , for RS 640. I even called the Konami helpdesk. They were also unable to give any solution.
Old 20-07-2006, 06:01 PM   #6 (permalink)
PrinceHeart's Avatar
Start > Run > "dxdiag" ENTER
It opens DirectX Diagnostic Tool
Go to Display on TOP
Test DirectDraw
Test Direct 3D
Install latest DirectX from http://www.microsoft.com/
repeat those tests again
change screen resolution to 800 by 600 pixels
try to run the game, assuming the game is installed correctly and the game CD is in your CD-ROM or you got NO CD patch or something ( can't help in those types of patch stuffs).
Hope it helps
cheerz
*PrInCe*
PrinceHeart is offline
Old 20-07-2006, 07:23 PM   #7 (permalink)
Nope, none of this helps
Old 20-07-2006, 09:54 PM   #8 (permalink)
thunderbird.117
Posts: n/a
You see the game worked on P 3 very well. When playing the game in P 4 with grapics card the game does not play.
Go to options see if it you change to hardware mode or to software mode. See if one of them settings work.
Old 23-07-2006, 06:01 PM   #9 (permalink)
I can see nothng in the game. How can I change the mode?
Can it be done by manually editing the game files?
Old 23-07-2006, 06:50 PM   #10 (permalink)
shashank4u's Avatar
try updating graphics and audio driver from intel's site or if u have new one
try with older drivers.
shashank4u is offline
Old 23-07-2006, 07:08 PM   #11 (permalink)
Already did that
Old 26-07-2006, 09:36 PM   #12 (permalink)
sysrq's Avatar
http://www.konami.com/main/cgi-bin/u...5;t=000381;p=0
not sure if this would work for ur GMA900, cause that fix was for gfx cards. any way try it first. download nocd one if u like.
this happened to me b4 but this was a issue with game[grayness... etc], so
if that succeed ,get a analog gamepad like ps2 to enjoy full cinematic gameplay.
[2] if nothing works try the game with charecter detail to 2nd lowest or lowest option, if again all fail then try desabling vertex shader.
desabling vertex shader does helped me but i have gfx card[was a proud owner of intel ext gfx 2 b4 perchasing card] and i did that by rivatuner.dont know how to desable VS on gma900 or intel ext gfx 2.
sysrq is offline
- by gohan89
