Old 18-07-2006, 03:06 AM   #1 (permalink)
Cool XP 64 bit problem with audio..help me..plz
hi ,
My friend bought AMD 3000+(venice core)
MSI rs 482 m4 , the problem is when i installed 64 bit os , unable to install
audio drivers ,.
but i can install audio driver s on 32 bit os with sp2 on same system .
plz help me
hermit
hermit is offline
Old 18-07-2006, 08:04 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: XP 64 bit problem with audio..help me..plz
Whats the soundcard? Tell me the name of the drivers you install for 32 bit.
kalpik is online now
Old 18-07-2006, 11:41 AM   #3 (permalink)
Try http://www.planetamd64.com if u haven't already. Yeah also wen u mention problems like this do mention the sound card manufacturer it helps
junglee_mard is offline
Old 18-07-2006, 08:27 PM   #4 (permalink)
I faced the same problem for my ECS board. You have to search the microsoft website for thefix. TThere is pone avaiable there that u have to installl before installing the sound drivers.
I am not arrogant, just better than you
snake eyes is offline
- by gohan89
