Old 15-07-2006, 12:44 PM   #1 (permalink)
Default How to Switch between 2 OSes
Is there a way to switch between to OSes – Win 98 SE & Win XP in my case, with out restarting the computer?
Aanand is offline
Old 15-07-2006, 01:06 PM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: How to Switch between 2 OSes
well i think u will need two computer for that
or may be those virtual computer softwares
Rollercoaster is offline
Old 15-07-2006, 01:22 PM   #3 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
without restarting its not possible to boot into another OS like using switch user system in xp but there is a s/w called xosl which gives u some options for people having 2 or more OS..check it out
rakeshishere is offline
Old 15-07-2006, 02:32 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
The only way is to boot into XP and then start Virtual PC or ne other similar s/w and then start win 98 in that s/w (virtually).
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
- by gohan89
