Originally Posted by homiyar
It gives the same beep even if I switch on the PC after removing the RAM.
how can a computer work without it ,it will surely give long beeps
most probably ur ram has died or there is a prob with the mobo ram slot check ur ram in ur friend's system if it gives the same beeps then it is gone for sure
else ur memory slot on the mobo is gone
the frequency would most probably be 100 or 133 mhz as it is SD ram
