Old 12-07-2006, 02:27 PM   #1 (permalink)
Default IP range calculation??????
HI,
can anyone tell me on how to know the total no of IP that can be used given a IP and a mask.
say: 10.202.18.8... this last octact i.e. 8 is a bit confusing. can be 9/10...
Mask 255.255.255.240
is there any program to get this done???
regs
ken
taken is offline
Old 13-07-2006, 10:46 AM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Default Re: IP range calculation??????
10.202.18.8 is a Class A address and the mask 255.255.255.240 or /28 or 4 bits borrowed.
Now Class A address have 8 bits for network portion and 24 bits for host portion. Now number of subnets created with this config is :
2^4 = 16 total subnets
and 2^4 - 2 = 14 usable hosts per subnet.
You can use Semsim for these calculations.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 13-07-2006, 11:18 AM   #3 (permalink)
ninad_mhatre85's Avatar
hii taken there are 5 types of ip add A, B ,C, D ,E. we dont use D & E
ip add contains network & host part .
so to identify host part from total ip machine use subnet mask so subnet mask by default is
A === N:N:N:H(total ip) mask == 255.255.255.000
B === N:N:H:H(total ip) mask == 255.255.000.000
C === N:H:H:H(total ip) mask == 255.000.000.000
wher N>network, H> host
i dont know whether u know abt binary AND operation this mask is ANDed with ur ip find out host
if u know binary system u can identify ip class just convert ip into binary
eg. 64.64.64.12 >>> 01000000.01000000.01000000.00001100
and check for first(s) digits
A== 0
B== 10
C== 110
D== 1110
E== 1111 just check with ur add
for ur case ur ip is 10.202.18.8> 00001010. 11001010.00010010.00001000
so first bit is"0" hence its class A
ninad_mhatre85 is offline
- by gohan89
