Old 11-07-2006, 11:39 AM   #1 (permalink)
Default Problem installing SP2
Sir,
Im using p4 2.4 GHZ 256 RAM and mercury P4M266a motherboard,i tried to install
service pack 2 in my win xp home edition,everything installs smoothly but after complete installation and reboot i experienced boot failure and it failed to boot in
safe mode also, i have formatted my hard disk and the problem still persists,but it is smooth with SP1. How to solve this?
ahamednms is offline
Old 12-07-2006, 11:31 AM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Default Re: Problem installing SP2
If you have a licensed version of Windows XP, I'll recommend you to create an SP2 integrated install cd and try installing with it. [*] XP SP2 Slipstreaming
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 12-07-2006, 08:47 PM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
try diffrent sp2 file. the file might be courappt
gary4gar is offline
Old 13-07-2006, 08:36 AM   #4 (permalink)
I tried using slipstreaming cd,but same problem again ,,anyway thanks!!!!
Old 13-07-2006, 06:16 PM   #5 (permalink)
Hi
Probably ur copy is corrupted.I have a similar PC as yours and with the same WinXP Home with SP2 but I'm not experiencing any such problem.
pensiveprodigy is offline
Old 13-07-2006, 06:34 PM   #6 (permalink)
pop143's Avatar
Smile Re: Problem installing SP2
hi friends..
i do have WIn xp home edition. its not even installed with sp1.
i want to install win xp sp2..can i directly update with sp2..or shud i do sp1 first ..really i donno. can anybodytell me..??
moreover was it provided in our digit cd/dvd ..??? can u say wot month it was/.??
how much mb wud it be..approx ...????
heard win xp sp3 also released...????
pop143 is offline
Old 13-07-2006, 07:12 PM   #7 (permalink)
dIgItaL_BrAt's Avatar
1.yes,direct update is possible
2.Sept 2004/June 2005
3.266 MB
4.No
dIgItaL_BrAt is offline
Old 13-07-2006, 07:18 PM   #8 (permalink)
The Frozen Nova
casanova's Avatar
Yes u can directly install sp2. Sp1 is not needed to install sp2.
Further, it was present in the June 2005 DVD. The freeware /anniversary issue.
It is a 266MB download.
SP3 is not an official release. It is just a collection of all post sp2 updates.
www.nerdweed.blogspot.com
casanova is offline
Old 13-07-2006, 07:49 PM   #9 (permalink)
pop143's Avatar
thank u guys. oops i dont have both the dvds. so waiting for another release in the short comings...BTW..so we need sp2 b4 we insatll sp3..am i right..?
pop143 is offline
Old 14-07-2006, 11:55 AM   #10 (permalink)
No .. Windows Service packs are cumulative updates .. That means if you install Sp2, you dont need to install Sp1 .. There is no stipulated date for SP3 yet ..
Old 14-07-2006, 06:09 PM   #11 (permalink)
pop143's Avatar
Wink Re: Problem installing SP2
then , whn sp3 is released it wud include all teh things released in previous sevice packs also.."casanova" user previous post he said , sp3 is a collecion of updates, so i got a ques to install sp2 and tehn get into sp3;
thansk bye;
pop143 is offline
Old 14-07-2006, 07:46 PM   #12 (permalink)
tosh_mine's Avatar
i got the same problem a few days before.Finally the problem diagnosed was my motherboard didnt support the installation. Finally i got my motherboard replaced(It was under guarantee). And now i have service pack 2 installed on my pc.Check for ur motherboard.
tosh_mine is offline
Old 14-07-2006, 08:41 PM   #13 (permalink)
photon's Avatar
Angry Re: Problem installing SP2
SP2 will not be installed on a duplicate installation CD. Think something different. any help?
photon is offline
- by gohan89
