26-11-2004, 12:23 PM
Can norton and avg exist side by side on one system?
Just wanted to know wether anyone is using the above combination together??
I wanted to use avg as a lot of ppl on this forum have raved about it but i don't want to remove Norton without being completely sure that avg is worth it.
Comment please !!
Quote by Garfield'
26-11-2004, 12:35 PM
You can use both side by side but performance decreases and there is a probability of 'lock ups' as Norton doesnt allow other softwares to scan some files.
http://swatrant.blogspot.com/
26-11-2004, 12:42 PM
Then disable Norton's live protection and any other memory resident features, and use AVG ... I too did like that and then completely switched over to AVG
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
26-11-2004, 12:44 PM
Its certainly not advisable to have 2 anti-virii or 2 firewalls on a single system.Conflicts could arise due to this which would be hard to sort out.
www.Oobertech.net
26-11-2004, 03:45 PM
Yah.. dude.. You can have them together on the same system.. But it degrades the system performace., I dont think there's any need to have them together.. But.. In my view Norton is better than AVG thou it eats up ur RAM..
27-11-2004, 07:55 AM
why u need 2?
Use Norton 2005. Better performance and take low resources.
My Trip had been cancelled.So I will be here with you .
-Lavan joy@Lavan_joy since Dec 2003
27-11-2004, 08:57 AM
But when u use Windows XP with SP2, there might be probs ! Coz I had Panda Antivirus and later installed Norton 2005, guess wht happened ? System crashed !
@ Booting windows did not know which antivirus to start with, both had a conflict, like they fight to get the priority !
Regards,
Vinay
Vande Mataram - Two words that became a Fiery War Cry and Electrified the nation towards Freedom. A mantra that instills a sense of Pride and belonging.
27-11-2004, 09:38 AM
On no condition run their "live protection" or "resident shield" engines together, but you can install them both together ... no problems.
27-11-2004, 01:28 PM
I understand the live protection bit but whats "resident shield" ??
Quote by Garfield'
27-11-2004, 02:59 PM
Those are two names for the same thing ...
27-11-2004, 03:41 PM
So what you are saying is they can run to-gether but with one of their live protections disabled.
So they can both be co-existing in the system tray?? or one can be and the other can be switched on for just an extra caution scan or something.
Is this really possible?? seems as though its a recipe for some serious conflicts and resource hogging. Because dont the anti-virus stay in the background but are using system memory............
Quote by Garfield'
27-11-2004, 05:25 PM
Hmm.. I use Norton 2005 with Live Protections, it some times helps me find some internet !
Wooooooooo ! Just @ time I was posting this I got one more alert, check this screenshot if you wish !
27-11-2004, 06:51 PM
Yeah exactly ... you may be able to run em both but expect crashes. As for resources ... yeah both will reside in the memory.
28-11-2004, 01:10 AM
Instead of two AV you use AVG 7 Free Edition combined SpyBot SnD1.3.You will be protected.
28-11-2004, 11:42 AM
I WANT MORE FPS!!
I installed Norton Systemworks. Now even dave works slowly. forget about ut2004. I feel a computer with 100 virii is faster than a computer with norton. Get AVG only. acgres process is very small. It requires no ( as Limit  0 ) cpu and very low mem usage. Can run UT 2004 smoothly with it running. No performance chage at all. Just rremove the control centre.
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
28-11-2004, 01:07 PM
Just go for AVG
Forget norton and go for avg .. Its free and its fine ..
Rather disastrous for ppl like me
