Old 08-07-2006, 10:50 PM   #1 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Question Internet Explorer Beta 3 problem?
I dwnld Internet Explorer Beta 3 from www.softpedia.com...It was a compressed SFX archive...I extracted the archive using winrar to a separate folder and not the default folder where the previous Internet Explorer was installed...Then i wen to the folder where it was extracted...There i got a folder called "UPDATE".i clicked on it and inside i found a file called "Update.exe"...I clicked on it and it started updating my previous version of IE....50% of progress happened and then it discontinued...i waited for 90 min and still there was no progress...i just closed it and again tried clicking the file Update.exe...this time also i got the same result...Due to this IE is screwd and it doesnt open...I have no probs coz i use firefox but how do i solve this problem...I got the new icon of Internet Explorer Beta 3 but it doesnt open coz the installation didnt progress...
rakeshishere is offline
Old 09-07-2006, 12:19 AM   #2 (permalink)
dattebayo
anispace's Avatar
Default Re: Internet Explorer Beta 3 problem?
pirated windows i guess....else download from microsoft.com, it works.
anispace is offline
Old 09-07-2006, 01:54 AM   #3 (permalink)
HELP AND SUPPORT
Smile Re: Internet Explorer Beta 3 problem?
Mine is not pirated...If dont know the solution no rubbish allowed here
Old 09-07-2006, 09:07 AM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
You dont need to extract it. Just double click and the installation will begin.
kalpik is online now
Old 09-07-2006, 04:00 PM   #5 (permalink)
samrulez's Avatar
The main file should be a cabinet file......I got a cabinet file...just execute the file.......
Sam :D Rulez :lol:
samrulez is offline
Old 09-07-2006, 05:20 PM   #6 (permalink)
dattebayo
anispace's Avatar
Yeah its a cabinet file named "IE7BETA3-WindowsXP-x86-enu". U might have set winrar to open cabinet files. Just run the file directly... and it should work.
@rakeshishere
I just suggested u download from microsoft.com if u have genuine windows.
anispace is offline
Old 09-07-2006, 09:54 PM   #7 (permalink)
Wandering in the zone ...
manas's Avatar
Try downloading from www.microsoft.com and then installing it.
Not all those who wander are lost. :D
http://www.manast.com ---- ManasT
manas is offline
- by gohan89
