| Forum |
#1 (permalink) |
The Thread Killer >:)
This install file works fine with ALL the PCs I have tried. I use this complier as the same compiler is used in college and I need to port my programs from college to home often. So guys, please don't suggest a different compiler for me, atleast for now. I face the same problem while using MASM as well. I will give you my specs of my system. PLEASE HELP OUT THIS POOR SOUL. My system specs: AMD Athlon 64 3200+ (Socket 939) MSI RS-480M2 motherboard 160 GB SATA Seagate HDD 512 MB DDR RAM (Hynix) Windows XP Professional Build 2600 I also tried by installing service packs, no use. |
#2 (permalink) | |
Try reinstalling.
There shouldnt be any issues coz Borland follows ASCII code and both TurboC++ and Borland C++ are by the same company, viz Borland. TurboC++ is way 2 old...i dunno y all schools and colleges r sticking to it
~"Computers are useless. They can only give you answers."~ |
#3 (permalink) |
Thanks for the quick reply, but I need to find out why this is happening on my system. I did try Borland, but the same code doesn't seem to work properly and its taking me loads of time to get used to it. So guys, please let me know what is causing this irritating problem.
Hope to hear a final solution to this problem. Thanks in advance again. Bye. |
#4 (permalink) |
C# Be Sharp !
well turbo c++ 3 doesn't work under windows XP , you'll have to make a new partition on your drive , install dos on it and then run turbo c++ under dos .
IM me if u want more help .
There are 10 types of people in the world: those who understand binary and those who do not. |
#6 (permalink) |
yes, it does work under XP...i dunno which version..but it does
Second thing, the problem isnt with NOT WORKING, its with faulty working. AFAIK, TC++ doesnt come with an installation setup...its just copy-paste-and-run. Maybe some file is corrupted, tryt getting another copy and use it PS: borland commnad line is very easy to use if u integrate scintilla editor with it. It functions just like TurboC++ win GUI program (version 4.XX)
#7 (permalink) | |
Well, my problem somehow got fixed all by itself I don't know how. I just re-installed TC++ and it was working fine. I don't know what caused it to work right. This is the first time it worked properly since I bought my PC. According to the sticky post regarding the 16-bit windows system, that helped me out to know something. That might have been the problem, but I have kept a backup of the file posted there. I shudder to reinstall my OS even if something goes wrong it might trigger the unknown event of making my compiler go awry. Crossing my fingers and working on it. |
#8 (permalink) | ||
@phreakoutt try checking option->editor settings.... this might help u ... as some one might have just changed them Quote:
who the hack is this?? |
#10 (permalink) |
left this forum longback
I'll suggest you to try GCC's g++ compiler for C++,and move to a GNU/Linux version with IDE's Like Anjuta etc...GCC is much updated to ANSI/ISO specifications.why to use old/pirated Turbo C/C++ versions!?
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
#11 (permalink) | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
