Results 1 to 12 of 12
  1. #1
    Alpha Geek ashfame's Avatar
    Mar 2006
    Delhi / Jaipur
    Default win xp home sp2 / pro sp2
    guys wht r the things missing in home ver. when looking @ pro ver.
    My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
    HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
  2. #2
    Commander in Chief QwertyManiac's Avatar
    Jul 2005
    Default Re: win xp home sp2 / pro sp2
    Jus some netowrking features and IIS, nothing much to worry about, if you use it for commercial purposes over loads of computers, buy the Pro, else go for home for a limited amount of computers on network.
    Harsh J
    www.harshj.com
  3. #3
    Mar 2006
    Delhi / Jaipur
    details
  4. #4
    I Always Prefer 1080p techtronic's Avatar
    May 2006
    Cool Re: win xp home sp2 / pro sp2
    XP Home doesnt support
    1.REMOTE DESKTOP
    2.IIS OR INTERNET INFORMATION SERVICES
    3.OFFLINE FILES AND FOLDERS
    4.EFS OR ENCRYPTING FILE SYSTEM
    5.GROUP POLICY
    6.SOFTWARE INSTALLATION AND MAINTENANCE
    7.ROAMING USER PROFILES
    8.REMOTE INSTALLATION SERVICES
    9.MULTI-LINGUAL USER INTERFACE
    10.DUAL CORE PROCESSOR
    on the other hand XP PRO SP2 rocks
  5. #5
    Mar 2006
    Delhi / Jaipur
    Quote Originally Posted by techtronic
    explain this
  6. #6
    Jul 2005
    Sure it doesnt support dual core? It does support dual core but not 2 physical cpus man.
    Harsh J
    www.harshj.com
  7. #7
    Mar 2006
    Delhi / Jaipur
    ^^ Post #5
  8. #8
    Jul 2005
    Are you asking me? AFAIK the only big factor for home users was that they were missing IIS, so installing VS would become a problem. Anyways if you use your comp for devel purposes mostly use Pro, kinda makes installing stuff easier and no dependency troubles.
    Harsh J
    www.harshj.com
  9. #9
    Mar 2006
    Delhi / Jaipur
    Quote Originally Posted by QwertyManiac
    what is VS?
    pl explain in details (typo-god)
  10. #10
    Nov 2004
    Madurai
    If you are ever in an environment where you have to do network sharing, etc where you need to look into security aspects, etc... such as you may have in a small office, etc... I would strongly advice against WinXP Home.... I have used both.... In a simple home environment, XP Home is fine... When you have even the smallest of office environments, configuring security in XP Home is a hassle...
    Arun
  11. #11
    Mar 2006
    Delhi / Jaipur
    Only home pc work not much.
    i access net thro LAN so which one is best for me?
    Non-Genuine XP pro / Genuine XP Home
    And wht if i shift to mtnl that provides thro router
  12. #12
    Jul 2005
    VS is Visual Studio (MS's .Net development IDEs)
    Home is cheaper and good for small networks like sakumar has already mentioned. May be a wiser buy sinc we can install almost all stuff on it like we can install on Pro.
    Harsh J
    www.harshj.com
  1. Replies: 2
    Last Post: 10-04-2012, 12:26 PM
  2. difference between Windows 7 home basic & Windows 7 home premium
    By siddheysh in forum Laptops and Netbooks
    Last Post: 29-04-2011, 03:16 PM
  3. Connecting Vista Home with XP home
    By navisangha in forum Software Q&A
    Last Post: 09-11-2009, 01:32 PM
  4. Replies: 18
    Last Post: 15-08-2008, 12:09 AM
  5. WinXP Home(German) to WinXP Home(English)
    By PrinceHeart in forum Software Q&A
    Last Post: 17-09-2006, 01:50 AM
