Old 20-06-2006, 04:38 PM   #1 (permalink)
Default regedit and ping problem
when i go to run command in start menu and type regedit or ping it gives a error msg saying regedit is not a valid win32 application... same is the case with the ping command... earlier it was working fine... wat 2 do now????
ashishkhetriwal is offline
Old 23-06-2006, 04:59 PM   #2 (permalink)
shovik's Avatar
Default Re: regedit and ping problem
then it should have happened that some or the other ur regedit.exe has corrupted. Goto the link below to have more info about ur problem:
http://www.liutilities.com/products/...brary/regedit/
http://www.auditmypc.com/process/regedit.asp
you can also use third party registry editor from the link below:
http://www.sharewareconnection.com/t...egedit-exe.htm
Regards,
Shovik.
shovik is offline
Old 25-06-2006, 05:55 PM   #3 (permalink)
go_gamez's Avatar
i think u shud try XP repair pro ..i had the same problem but now its repaired by the above software..its really cool software..
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
- by gohan89
