Old 19-11-2004, 01:44 PM   #1 (permalink)
Default Volume Icons mysteriously dissapers. DEvice cannot start
For the past couple of days my volume icon on my laptop has been dissapearing and reappearing with eavery startup.
Sometimes it loads and sometimes it does not. Its a very strange thing. I check the device manager and it says that this Device Cannot Start (Code 10).
Ive even uninstalled the drivers for my sound card
Interl(r) 82801CA/CAM AC'97 Audio Controller
I am currently runnign Windows XP Pro and have Mcafee Anivirus installed.
What can be done? Does this mean that my sound card is a gonner?
I dont get it, as the driver n all install just fine.......its just the message that I get after that which say the device could nto start. Weird.
Keep The Passion Alive!
Destructo is offline
Old 19-11-2004, 07:18 PM   #2 (permalink)
NikhilVerma's Avatar
Default Re: Volume Icons mysteriously dissapers. DEvice cannot start
Did you reinstall it or you left is as it is??!!!
I had similar problems earlier ... But only becoz of bad drivers...
try to get updated drivers for your device
NikhilVerma is offline
