Installed Norton AV or personal firewall after a restart i get a message box that says a hacker or virus is trying to prevent the AV or firewall to run. This is on XP
But when i installed AV and firewall on Win 2000, alls fine
Plz help what may be the prob.
__________________ Its your attitude not your aptitude that determines your altitude.
simpaly run the Quickheal setup which scans the files b4 installation..it will tell u if there is any virus or not....also try to install some other filrewall app..if the prob persist then am afraid silvertwins is right u'lll hav to format it...
try to see if u have the windows firewall enabled or not.
try running adaware and spybot snd.
try ne online virus scanning from symantec,trendmicro or panda antivirus.
