| Forum |
#1 (permalink) |
Location: If I had a webcam u could have seen me, before your eyes.
Searching for dell studio 15 ?? dell studio 15 review @ my blog vandit007.blogspot.com And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !! |
#3 (permalink) |
If i copy the boot.ini from my freind's PC having dual boot will it work??
#4 (permalink) |
I did the fixMBR and Fixboot thing .... now i m getting win xp and 98 two options but when i select the xp option the comp. restarts..... plz help...
#5 (permalink) |
!FREEWARES!
Try restoring all the missing/modified system files of Win XP using the Win XP
boot cd. There is a specific command for this which had come in one of the DIGIT issues. May b someone here can help with the exact command
MBP 13.3"; PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370 |
#6 (permalink) |
Hi
I am geting the same problem .I have lost boot.ini on formatting c:.I have loaded win98 on c:.I have winXP on D:.Can someone post boot.ini having win98 on c: and winXP on D: TIA rajeev chavan |
#7 (permalink) |
HI
Alternatively pls tell how to run fixboot.When I started recovery console I got to d:\windows diretory . What is to be done from here onwards to run fixboot.Pls advice rajeev chavan |
#8 (permalink) |
-The BlacKCoaT Operative-
well u have mixed everything up.. i have a fool proof way to get it corrected but mind u it is long..
Ok so we have 3 OSes.. win98 winxp linux We shall recover them in the fashin they get installed namely first we recover windows 98 booting then windows xp then linux Kool. lets start..... 1. Identify ur boot partition(active) if u have not changed it while messing around pop in win98 boot disk/floppy and at prompt write a:>fdisk here view the existing partitions and see the active one. restore the active partition if u had changed it before. 2. recover Win98 boot if u changed the boot part above restart the pc. Pop in the windows bootdisk When u get to a:> write "fdisk /mbr" <<without quotes http://support.microsoft.com/kb/q69013/ This will write the default windows 98 startup (remember those blue 640x480 starting windows 98 screen) Now restart and see that u can boot into windows 98. If everything was write till nowu should be able to boot and run win98 successfully. Restart. 3. Recover Win XP boot Pop in the bootable windows setup cd/floppy Choose 'R' for recovery console It will ask for which Win XP setup chooose one Now give the Admin password when it asks when u get the prompt the write two commands "fixboot [drivename]" e.g "fixboot c:" if c drive is the obe u set active http://www.microsoft.com/resources/d....mspx?mfr=true "fixmbr" http://www.microsoft.com/resources/d....mspx?mfr=true Now restart You should get basic 30 sec menu to choose which os to boot(xp/98) if everything is ok till now 4. Recover linux boot Ok i am familier with GRUB only andthat too in Redhat fedora core Pop in the linux setup cd no 1 Boot off the cd. At the boot prompt, type 'linux rescue' (no quotes) and hit enter. continue with the default options through the prompts. when you get to a bash prompt, type 'chroot /mnt/sysimage' (change the path to where ever your boot folder is). Then, type '/sbin/grub-install /dev/hda' (assuming, hda is your system drive) Reboot your computer off the drive. OK now u r back online. Boot.ini see here http://support.microsoft.com/?id=289022
-------------------------------------------- Holding my last breath, safe inside myself..... -------------------------------------------- I dont use my computer. I misuse it- रोलरकोस्टर Last edited by Rollercoaster; 18-06-2006 at 07:10 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
