Old 28-05-2006, 09:29 AM   #1 (permalink)
tiblu's Avatar
Question Pirated Or Not
Hey guys i hav a branded pc it came loaded with winxp, now my question is that do i have original windows xp or not, is it safe to use pirated winxp on the internet. can i use windows update.
tiblu is offline
Old 28-05-2006, 10:22 AM   #2 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default Re: Pirated Or Not
most probably than not ur PC is using original as u have a branded PC( if it is a well known brand) u cant use windows update if it is pirated...
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 28-05-2006, 10:59 AM   #3 (permalink)
Distinguished Member
anandk's Avatar
Talking
yeah, if its a (known) branded pc, ur's must be having a legit winxp. didnt they give u the xp cd !? if its pirated, and if the serial is known to have been leaked, then u will not be able to update. but it is nevertheless safe to surf the internet without the updates, provided u use a good antivius/anti-spy/firewall. avast/adaware/zonealra r some good freeware in these categories respectively. u can search for them at www.download.com
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 28-05-2006, 11:59 AM   #4 (permalink)
Tux Fan
shaunak's Avatar
if it is absolutely new and you were promised xp with the pc you can verify the validity of your windows at howtotell.microsoft.com ; if it is pirated it is your right to demand for a original copy and report your dealer.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 28-05-2006, 12:00 PM   #5 (permalink)
ashfame's Avatar
automatic updates downloads the updates for the xp even if it is not genuine.
no genuine check is required when windows is updating itself.
but has a doubt do they get properly install b'coz once i saw log file of an update which shows repeated failure of installation but in control panel > add remove it shows installed.
Well i know one way of getting updates from net without a genuine copy of OS, is there any way i can report to Microsoft to get something back in return.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 28-05-2006, 11:20 PM   #6 (permalink)
samrulez's Avatar
Mostly u will have a legal version coz its a branded one........see wheather u have the license it looks like booklet and says that u have an original version of windows......
Sam Rulez
samrulez is offline
Old 29-05-2006, 01:39 PM   #7 (permalink)
royal's Avatar
Cool Re: Pirated Or Not
it is perfectly possible to get windows update on a pirated OS
royal is offline
Old 29-05-2006, 02:05 PM   #8 (permalink)
PrinceHeart's Avatar
Many ppl download millions of softwares from the internet everyday and many ppl buys new hardwares.. why don't ppl buy original XP. it only cost >Rs. 2000.
Well.. just thought i would say that here.. I got original XP now.. before i was using pirated. Since windows Xp got that genuine validation tool. It got me worried, so i got the original XP key now. And to tell you all. Its nice to see when microsoft says.. "Thanks for being a Genuine Customer" - good to smile looking at that
and believe me it worth it too.. dunno what microsoft will do next.. they NEVER tell the secrets... only what they want the public to know. Just the small bitsies.. the rest big stuffs they keep to themself. I am MSC and a beta tester, i know. If anyone use windows as their OS, better get an original one. I didn't got any problems running many softwares since i got the original XP.
cheers
*PrInCe*
PrinceHeart is offline
Old 29-05-2006, 02:51 PM   #9 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Talking Re: Pirated Or Not
Well, i still made my WIN XP look original and Genuine to MS even thou i was being bugged up by tat annoying GENUINE TOOL crap...
Totally agree with u bro...
BTW tiblu, jus go to microsoft.com and try if MS recognises ur copy of XP to be legal or not.. BTW U must be having the CD/Box Pack for the WIN XP OS.. isint it ???
Cheers n e-peace......
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 29-05-2006, 02:54 PM   #10 (permalink)
GaurishSharma.com
gary4gar's Avatar
go to microsoft.com and check there
gary4gar is offline
Old 01-06-2006, 04:41 PM   #11 (permalink)
tiblu's Avatar
what happens if my winxp is illegal or pirated will there b any charge on me or some kind of fine by microsoft.
tiblu is offline
Old 01-06-2006, 04:50 PM   #12 (permalink)
ashfame's Avatar
nothing bro, when u will go to their site, they will just tell u that u might be a victim of software fraud, click here to buy a genuine xp, blah blah....
And u r done! they won't do anything else
ashfame is offline
Old 01-06-2006, 06:20 PM   #13 (permalink)
The pWnster
Vyasram's Avatar
if they fine and charge users, 78% of indian pc users will be on jail.
Nothin happens.
Btw ms has thanked me 4 usin genuine win xp though the version i hav is pirated... cool
Sigs suck
Vyasram is offline
Old 01-06-2006, 06:43 PM   #14 (permalink)
I guess more than 78%
@princeheart . Microsoft xp >2000 . Why only 2k its also greater than 3k and 4k . Its somewhere above 5k.
There are no student copies of such software like in other places and this is what makes me go mad at them
cyrux is offline
Old 01-06-2006, 08:55 PM   #15 (permalink)
tiblu's Avatar
Ok Thkx
tiblu is offline
Old 01-06-2006, 09:32 PM   #16 (permalink)
now it seems like 3.5k or so that too maybe a year or so ago
akshayt is offline
Old 01-06-2006, 09:37 PM   #17 (permalink)
tiblu's Avatar
How much Window Xp Pro Costs?
tiblu is offline
