Old 27-05-2006, 12:47 PM   #1 (permalink)
hcp006sl's Avatar
Lightbulb How to remove ZAP or IMSecure Pro, if get corrupted - A tutorial
Recently my IMSecure and ZoneAlarm got corrupted due to accidental deletion of some important files of these software. Then I have to take the premium support facility available from Zone Labs. I wrote a mail to Zone Labs. In reply they sent me the procedure of uninstalling ZAP and IMSecure manually. I thought I should share it with you so that if you face such situation this article would help you.
The article you would find at my personal site - the link is:
http://hcp.wincustomize.com/articles...843&AID=118828
Orkut members are invited to join:
http://www.orkut.com/Community.aspx?cmm=28705185
hcp006sl is offline
Old 27-05-2006, 03:05 PM   #2 (permalink)
aryayush's Avatar
Default Re: How to remove ZAP or IMSecure Pro, if get corrupted
Thanks a lot! Though I have never yet faced a problem with the software, your article might indeed be of value if anything does happen to it. Thanks again!!
Miss me already? See you on Penned Thoughts [http://aayush.me] then. Adios!
aryayush is offline
Old 27-05-2006, 07:18 PM   #3 (permalink)
prasad_den's Avatar
Good info.... Should be in the tutorials section for better reach...
prasad_den is offline
Old 28-05-2006, 04:12 PM   #4 (permalink)
hcp006sl's Avatar
Smile Re: How to remove ZAP or IMSecure Pro, if get corrupted
Originally Posted by aryayush
Thanks a lot!
Welcome aryayush.
Originally Posted by prasad_den
Good info....
Thanks for appreciating.
hcp006sl is offline
Old 28-05-2006, 05:46 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
Smile
thanx Himangshu. its a rare piece of info. very nice of u 2 share it !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 30-05-2006, 07:06 AM   #6 (permalink)
hcp006sl's Avatar
Welcome anandk.
Yes, this is really a rare piece of info. Because, it's nothing but the mail directly from Zone Labs.
hcp006sl is offline
