Old 27-05-2006, 01:58 AM   #1 (permalink)
Default How to remove the "delete" when i right click on any file
Also how to modify all the items that appear when i right click on a file.
faraz_majidkhan is offline
Old 27-05-2006, 01:59 AM   #2 (permalink)
Default Re: How to remove the "delete" when i right click on any file
I want to do this using regedit
Old 27-05-2006, 08:22 AM   #3 (permalink)
Distinguished Member
anandk's Avatar
open regedit.
modify key HKEY_CLASSES_ROOT\.ext\shellex\ContextMenuHandlers
be careful !
software like winxp manager, superutilities, etc also let u do it selectively.
discussion on removing rtclick items here too
http://forums.mozillazine.org/viewtopic.php?t=30260
click here too on this cool link http://windowsxp.mvps.org/context.htm
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 27-05-2006, 10:17 PM   #4 (permalink)
i could not find the .ext under HKEY_CLASSES_ROOT
Old 27-05-2006, 10:20 PM   #5 (permalink)
i couldnt find the registry key specified by you
Old 28-05-2006, 09:11 AM   #6 (permalink)
anandk's Avatar
just search for 'ContextMenuHandlers'. its there !
else see the two link.
Microsoft® MVP
anandk is offline
Old 30-05-2006, 12:03 PM   #7 (permalink)
The Researcher
Originally Posted by anandk
open regedit.
be careful !
It is indeed a cool site. ThANK YOU. hOW CAN i SAVE THIS WHOLE SITE ONTO MY HDD?
Ramakrishnan is offline
