Results 1 to 4 of 4
24-05-2006, 10:02 AM #1Right Off the Assembly Line
- Join Date
- May 2006
- Posts
- 37
Need A Hard Drive based Mp3 player
Friends help me!
i need a hard drive based mp3 player(CHEAPEST POSSIBLE) which can play videos
the important factor here is that i will go for the cheapest possible model.
i just want music and videos(no thrills and frills such as fm tuner and gamea,etc)
24-05-2006, 01:32 PM #2
Re: Need A Hard Drive based Mp3 player
My advice to you would be to go for flash based as you are cost conscious.For an indepth look refer to may 2006 digit.
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
25-05-2006, 05:22 PM #3Banned
- Join Date
- Feb 2006
- Posts
- 115
dont buy the cheapest............it will last for 2-3 months and music quality is also bad . if u have a very tight budget i suggest u to buy ipod shuffle . basically what u want ? just to say that I HAVE AN MP3 PLAYER ? then u can go for the cheapest . otherwise if u r a music lover then buy a recomended MP3 player ............there is a very good CUBE shaped mp3 available at jjmehta.u can try for that.
25-05-2006, 09:02 PM #4Right Off the Assembly Line
- Join Date
- May 2006
- Posts
- 37
No.. I already have a flash based Mp3 player...I just want a player which can ply videos too ..and as most flash based players don't cross the 1 gb limit i think i wont be able to store a decent amount of movies and videos in it...i considered the nano and the fifth gen ipods but they are priced at 16,000...i think there is bound to be some cheaper models from creative, iriver and the others
and yeah i dont mean that i want a chinese made player when I Say CHEAPEST..(my budget is around 8k to 13k)
Pocket Hard Drive and My LG DVD Player
By vikcool812 in forum Hardware Q&AReplies: 2Last Post: 14-09-2010, 09:32 AM -
Help! I lost a big chunk of my hard drive based Ipod style player.
By Peter Bygrace for Digit in forum Hardware Q&AReplies: 2Last Post: 17-01-2007, 08:07 PM -
Formatting a flash based player
By ionicsachin in forum Software Q&AReplies: 4Last Post: 25-09-2006, 11:27 PM -
Hard Drive! Optical or Magnetic Based Drive
By Stitch in forum QnA (read only)Replies: 1Last Post: 30-05-2005, 11:14 PM
LinkBack URL
About LinkBacks
