Old 23-05-2006, 11:22 AM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default 5 Problems That I Faced: Need Solution
I am facing a lot of problems with windows xp which needs to be rectified. For this I need your help. Please do not tell me to format, as I also know it is the easiest way out. But I want to try the harder way because somebody asked me the question on another forum. “Who long a windows installation work correctly without any errors?”Earlier I used to format it every 1 or 2 months now I will give it try to use windows as long as possible. Currently my xp is celebrating is first anniversary. now I need your help to solve some problems. Please suggest any way possible other than freash intsall with or without format.
Config: Microsoft windows xp (built 2600), avast antivirus, Amd athlon 3000+ (754), 256 mb ram (64 mb video ram).
The problems are:-
Hanging windows-after I switch on the computer & the desktop is just displayed while the startup programs like avast antivirus is loading. The computer hangs just before loading of startup programs it comes stand still. Even the animated cursor stops. No matter how many times I press ctrl+alt+delete there is no effect .I have to restart it with reset button.
Late power down- it takes a lot more time than normal in shutting down of my pc. When I click on shutdown it responds quickly and imitated the kill all process but in last phase when welcome screen displays the msg ‘windows is shutting down’ it really slows down the hdd indicator light stops glowing after 1-2 min it finally power down.
Sudden restart- when I use my computer for long time i.e. is more than 2 hrs the screen turns black for 1 sec and it finally restarts. However it is to be noted that after restart the xp keeps on rebooting after the os choices boot loader. However windows-2000 is running smoothly at that point of time with no problems.
Noise-sometimes my computer makes hell of a noise even after I installed a chimney fan at the side of cabinet. Noise made is so irritating that I cannot my work on computer.
Disappearing Quick launch toolbar-my quick lunch bar is disappearing again & again after each restart and I have to enable it manually each time I use computer. What a painful task!
gary4gar is offline
Old 23-05-2006, 12:26 PM   #2 (permalink)
!FREEWARES!
Akshay's Avatar
Default Re: 5 Problems That I Faced: Need Solution
Try installing WinXP manager v4.96.1. It shud take care of ur 1st 3 and 5th prb. It will help u overcome some minor & major prb with win xp including startup/shutdown, registry prb. etc.
Cant say much about 3rd prb.
WinXP manager link:
http://www.yamicsoft.com
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Akshay is online now
Old 23-05-2006, 01:07 PM   #3 (permalink)
i think the noise problem is because of some prob in the fan....for the rest of the probs .... my only solution is formatting.....lol.....neway i must congratulate u for this gr8 performance....1 yr without formatting....awesome
manmay is offline
Old 23-05-2006, 10:08 PM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
@Akshay
downloaded WinXP manager.will see if it works
pls any more help
gary4gar is offline
Old 23-05-2006, 11:12 PM   #5 (permalink)
sknowonweb's Avatar
try keeping ur registry clean with easycleaner or similar such stuff .
Have an eye on startup programs .
[ run -> msconfig startup tab ]
That Late sys startup can be due to some startup prog suchas Adobe loader Office loader , and all such task tray stuffs .
keep the temp files clean .
தமிழ் வாழ்க
____________
EVIL : G00D :: YIN : YANG
________
sknowonweb is offline
Old 24-05-2006, 02:53 AM   #6 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
My last XP installation also lasted 1Yr. but I had To reinstall it recently because of similar problems and many others.
n00b forever...
~Phenom~ is offline
Old 24-05-2006, 07:54 AM   #7 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Just a guess, try un-installing Avast and then see..
kalpik is offline
Old 24-05-2006, 11:38 AM   #8 (permalink)
!FREEWARES!
Akshay's Avatar
With Winxp manager, u get all the tools u can ask for. Try using the registry
cleaner, delete unnecessary files, chk ur startup files, see what processes
are running & how much memory are they consuming, etc.
But be careful of the tool System repair under Optimiser - System repair -
repair system components...
I had to format my sys which didnt have any prb after I ran system repair though this mite help u...
MBP 13.3";
Old 24-05-2006, 01:38 PM   #9 (permalink)
the deconstructionist's Avatar
From the problem mentioned it looks more of a hardware problem. Check the working of the main components.In future use a good xp manager tool and formating is not the solution.
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
the deconstructionist is offline
Old 24-05-2006, 11:21 PM   #10 (permalink)
GaurishSharma.com
gary4gar's Avatar
i own a licencied tune-up utilities 2006 will it work b'cause i don't want to waste money on WinXP manager as it also is a shareware.i also use cccleaner.
gary4gar is offline
Old 25-05-2006, 11:21 AM   #11 (permalink)
a_g = JPKN
s18000rpm's Avatar
UnInstall The AVAST AV, my Cousin had similar Problems, When he Uninstalled That Stupid AVAST AV every thing came back to normal.
s18000rpm is offline
Old 26-05-2006, 08:11 PM   #12 (permalink)
Amargusain's Avatar
I agree bro. That Avast thingie does a lot of things to ur system.
post an uninstallation .. similar issues on my LT got rectified.
Worth a dekho.
Age is a high price to pay for maturity.
Amargusain is offline
Old 26-05-2006, 10:41 PM   #13 (permalink)
GaurishSharma.com
gary4gar's Avatar
will my VRDB deleted??
and i had to take the pain to generate it again
gary4gar is offline
