Old 18-05-2006, 05:49 PM   #1 (permalink)
Default Booting Problem
I have recently installed Suse Linux on my computer with Windows XP.Now whenever I try to boot into windows it shows the error
NTLDR is missing
Press a key to restart
I can boot into Linux.
Please help me
vineetrocks2005 is offline
Old 18-05-2006, 06:35 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Booting Problem
From XP Setup CD, copy ntldr file (It'll be in i386 folder) and paste to C:\ Drive.
If it doesnt help, then boot using XP Setup CD and give following command in Recovery Console:
fixboot
bootcfg /rebuild
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 18-05-2006, 06:46 PM   #3 (permalink)
!FREEWARES!
Akshay's Avatar
Boot up with the winxp cd, go to the recovery console and type 'fixmbr'. that restores the winxp boot menu.
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 18-05-2006, 07:20 PM   #4 (permalink)
does fixmbr command effects the linux booting
Old 19-05-2006, 11:05 AM   #5 (permalink)
!FREEWARES!
Akshay's Avatar
Once ur winxp boot menu is fixed, ur sys will boot in winxp. I am not sure abt the effect that "fixmbr" will have over linux but I guess u will have to reinstall/modify grub loader to be able to boot in linux.
I formatted my linux partition thru winxp after fixing xp boot menu
Refer to:
http://www.thinkdigit.com/forum/show...859#post238859
or
Suse Linux Queries...
& ask the techies there who knw linux in & out
MBP 13.3";
Akshay is offline
- by gohan89
