i have a network related problem for quite some time. The problem is my network monitor shows continous activity downloading packets from nowhere. During times windows even reports of a spyware(it turned out to be searchclick.cc/ some chm file but nothing in it after i clicked a popup that appeared in sytem tray) that it is stealing some imp data from system. I was not able to remove that spyware nor rectify the activity. I even tried AVAST spybot ad aware (and even my registry) but none shows any thing related to that file.Later i found in net the spyware (so called) could be removed by removing some files in system32 folder. And even after removing those files the problem continued.
The wierd thing in my problem is that i face the same problem in my LINUX FC3 OS also shows continous activity.And even wierd thing is that when i installed the same OS(the same CDs) in my friends comp even that showed same problem just after configuring network.
I even tried to find any clue using all network related commands i know in linux but in vain.
I am greatly worried about this problem . Where does this data come from and where does this goes into my hardisk. Is there any spyware that affects system in both the Os's Or is my system is being used as a zombie. The activity is nearly 2 Mbps (0.02 to 0.2% of my 100Mbps connection).
