Old 14-05-2006, 10:33 PM   #1 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default problem with plugin.
I recently downloaded the winamp plugin for using the infrared signals as input.... whenever i open winamp, a message comes....
whenever i press any button nothing happens..... the message remains open until or unless I close winamp..... how do i get rid of this message.....
NOTE: none of the buttons seem workin..
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 02-07-2006, 02:05 AM   #2 (permalink)
shovik's Avatar
Default Re: problem with plugin.
Its because you have downloaded a trial version of that plugin.....You either press 'Register Later' if it works. Or try entering the registration code to make it work.
Try downloading the plugin from ::http://remotew.free.fr/plugins.htm#winamp
http://tekgems.com/Products/WinampRe...edSoftware.htm
You can download a plugin pack which I have used and uploaded ::
The pass is : thanhtam-avaxhome.ru
I think that this info should solve ur problem.
Regards,
Shovik.
shovik is offline
