Old 09-05-2006, 01:26 PM   #1 (permalink)
Default problem with installing new os
i recently made a new partition using partition magic in order to install windows 98 SE. my present os is xp. also used boot magic to give me the menu option. after installation it loads only win 98. i cannot access the xp partition even after activating it using fdisk (on boot floppy). win 98 also cannot access my xp partitions. how do i get xp to work again? also bootmagic screen does not show up anymore.
philipmb is offline
Old 09-05-2006, 03:06 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: problem with installing new os
Following link will help U:
How do I install Windows® 98/Me after I've installed XP?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 09-05-2006, 09:56 PM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
ensure that ur partition are in fat32 format as 98 does not support NTFS
gary4gar is offline
Old 21-08-2006, 02:12 AM   #4 (permalink)
Dreaming Future
kin.vachhani's Avatar
There is no each thing as NTFS for win98........so u need to convert the partition to fat32 if u want access from 98.....
kin.vachhani is offline
