start>
run>
msconfig>
startup
over here
UNCHECK the programs that you do not want to be loaded by default.
Apply>
Restart Computer
Now after restarting a dialog box appears saying you have made some changes. click the box and say
OK
If the following hasnt speeded u booting u culd still try some others techniques like
.1. if u use windows blinds or any third party utility for beautifiaction and presentation of your desktop; startight away remove it.
.2.remove the desktop wallpaper. it culd speed up u r loading time by nano seconds only. not very noticeable by u; but culd help infact. here third party utilities like WEBSHOTS also shuld be disabled.
.3.from
Control Panel>
Sounds and Audio Devices>
Sounds> scroll down and remove the sound icon for
Start Windows and
Exit Windows.
if all these still didnt work. try the following too:
.1. Install a free Anti-Virus software from either
Antivir or
AVG or
Avast. all 3 are free versions and updates are released very often and kept upto date as best as possible and
scan your computer immediately. install only anyone of them otherwise it wuld clash against each other.
.2.Install and update Anti Spyware tools from both
Spybot - Search & Destroy and
Ad-Aware SE Personal. it is better to install both these as one plays a better role than the other at times. both are free versions and updated from time to time.
run a scan of your computer from both of them.
.3.and finally install a firewall preferably a software based firewall from
Zone Alarm
Read more :
Protecting your PC (excellent arcticle)
