| Forum |
#1 (permalink) |
Does it helps in boosting speed.. im having intel processor with EM64T.. will Xp 64bit will give extra boost frm Xp Sp2... Also r all the programs 64 bit compaitable...
!!!From DusT it StartS...... to DusT will EnD!!!! DusT = ME Rate me if was clear to you |
#2 (permalink) |
Learner
well it will be faster but most programs do not still have 64bit versions.... u will get all the drivers n all but u are most likely to run the programs in 32 bit mode even after u install winxp 64...
http://kniwor.wordpress.com/ |
#4 (permalink) |
Ya it is. But only if u have money to spare. And most importantly try it before buying it download the trial version from MS site
AMD Athlon64 2800+|ASUS K8N-VM|2GB DDR400|Corsair VX450|Seagate ST3500320AS|Samsung SV0411N|LG 22xDVDRW|LG 700S|APC ES500|Altec Lancing AVS300|Logitech MX3200|Logitech QuickCam Connect|Philips SHM6105 |
#5 (permalink) |
Wandering in time...
will all 32bit programs rum smoothly on windows 64bit??
and wat bout 16bit programs?? is turbo c++ a 16bit application??
Integrate Yourself With The Latest Happenings..... www.ankur-gupta.com/blog |
#6 (permalink) | |
Turbo C++ is a 16 bit software |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
