Old 08-04-2006, 06:19 PM   #1 (permalink)
Default Unmountable Boot Volume
Hi, I'm a new user to the Forum.
I have a Win 2000 Installed on my PC. I want to Install "Win XP Home Edition SP 2". I've tried various options like upgrade and new install. Things are allright till the PC reboots and comes to the "install raid device" and after that I think the PC does a hardware scan where upon the blue error sceen appears with the message "Unmountable Boot Volume".
In the same page it aslo says the regular message "if this is the first time you are seeing this message, reboot ........ contact your software provider for more help".
How do I get around this?
mbc_1824 is offline
Old 08-04-2006, 06:36 PM   #2 (permalink)
Default reply
even i had the Same prblm, didnt find the cause yet
Can nybody help
Andyiz is offline
Old 08-04-2006, 06:44 PM   #3 (permalink)
nishant_nms's Avatar
Plz post ur system configuration
nishant_nms is offline
Old 08-04-2006, 11:52 PM   #4 (permalink)
Default UBV Thread
Hi,
PC config: Cel 1.8, 256Mb, CDR, ST340810A (40gb Samsung HDD) i845g-ite8711 motherboard.
Anything More.
mbc_1824 is offline
Old 09-04-2006, 01:07 AM   #5 (permalink)
Learner
Kniwor's Avatar
just post ur partition table what does it look like
Kniwor is offline
Old 09-04-2006, 11:00 PM   #6 (permalink)
Default reply
where is the partition table?
Are u refering to Boot.ini File or something else
Andyiz is offline
Old 09-04-2006, 11:11 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
are you sure you have given the whole of the error u get?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-04-2006, 12:39 AM   #8 (permalink)
abhinavrakesh's Avatar
Take out all your PCI and AGP Cards from your motherboard Then Try Again then you will not get that blue screen may be some hardware is incompatible with sp2 version of windows xp so try to install windows xp without sp2 first then install BSOD patch from microsoft update site then install sp2
abhinavrakesh is offline
Old 11-04-2006, 12:07 AM   #9 (permalink)
::vicky::'s Avatar
try patition magic i think it is bad clusters if u have a 40 gb drive make 5 partitions out of it
::vicky:: is offline
