Old 08-04-2006, 12:04 PM   #1 (permalink)
Default Problem with DIGIT DVD's or My system?
I seem to have a strange problem. I purchased a new Acer Aspire AMD 64 System which has a CDRW+DVD combo drive. The problem is that this drive refuses to read DIgit DVD's only. All other DVD's it reads fine. I have other mag dvd's as well and they are being read fine. I dont understand what the problem is. The problem occured with last and previous months dvd as well. Problem is restricted only to Digit DVD's..
What can I do?
Thanx
Santo.
Santo is offline
Old 08-04-2006, 01:00 PM   #2 (permalink)
ashfame's Avatar
Default try digit dvd on another PC
try to run digit dvd on another PC, maybe ur friend's PC.
If they are read fine,problem may be specific to ur comp. but if they don't that means problem is Digit DVDs. Get in touch with Digit.
ashfame is offline
Old 08-04-2006, 07:53 PM   #3 (permalink)
dissel's Avatar
I think there was a registry entry.....might cause your problem.....
If you are familier with Windows registry.....then plz find this entry and delete it.....It can solve your problem.
HKEY_CURRENT_USER/Software/Jasubhai Digital Media
Remove the "Jasubhai Digital Media".......
Hope it may works.....
dissel is offline
