Old 08-04-2006, 12:01 PM   #1 (permalink)
Default IE 7 Woes
Some days ago i tried installing IE 7 beta 2 from Digit CD. I was knowing that it requires internet connection, but then also i tried. At one stage installer asks me to validate my copy of win XP by connecting to Microsoft's site. i clicked on validate & something happpened & then installer askes me to proceed ahead!!!. When i clicked on Next, installer installed necassary IE 7 files on my PC & asks me for reboot. After rebooting i was able to open IE 7!!!!!!!!
Thus i installed IE 7 Without internet connection.
After that i partitioned & formatted my HDD & installed Win XP with SP 2. Then again i tried installing IE 7 beta 2, the same way as done earlier, but this time i was unlucky.
Can u tell me why??????????
Bruce_Wayne is offline
Old 08-04-2006, 07:55 PM   #2 (permalink)
dissel's Avatar
I think that the previous installtion of WinXP is the Geniune Copy or it conatins a Genuine Licence Key.....
dissel is offline
Old 08-04-2006, 09:59 PM   #3 (permalink)
Boredom redefined.
PikachuTrAiNeR's Avatar
Simple.
SP1 that you used was original and contained genuine checker (you know, windows update). So you got it installed offline.
Besides that was a pathetic thing to do. SP2 can be installed within SP1, even though i'm 13, I can proove it to a <put age here>. ;D
Ppl should be a bit more logical!
PikachuTrAiNeR is offline
Old 09-04-2006, 03:17 PM   #4 (permalink)
Your Maker.
MysticHalo's Avatar
Did u ever try the windows genuine advtge check on the MS site, when u were running SP1 ? If yes, then it might have validated u and that info is stored in ur comp for future references.
BTW:guys, i dont believe that he was using a genuine copy of Win with SP1 and then switched over to use a pirated one just coz of SP2. The fact is that MS piracy detection system is abnormal. take my own case, it validates me as a genuine user and allows WinUpdt feature, but when i personally try to download ne thing that requires WGA check, it fails me.
And, as always, u have the tiny JS code for yer help
“Talent is a flame, but genius is a fire.”
MysticHalo is offline
Old 10-04-2006, 11:19 AM   #5 (permalink)
I installed Win XP from same CD, i used before & same SP 2 from one of the Digit's September 2004 CD.
Old 11-04-2006, 03:09 AM   #6 (permalink)
Your Maker.
MysticHalo's Avatar
Then i wud say u were lucky then but not now
May be the WGA sofware is updated...and now it detects ur copy as pirated.........but there's always a line of JavaScript to the rescue
