Old 31-03-2006, 05:18 PM   #1 (permalink)
D PrankMaster
prankie's Avatar
Default Problem installing opera!!!!
I recently reinstalled Windows XP Pro...
after which i downloaded latest version of opera, but when i ran the setup foll. error came
Could not open the DLL library
C:\DOCUME~1\xxxxx\LOCALS~1\Temp\GLF2B.tmp
Invalid access to memory location
Does any one knows the sol.
I am xtreemly addicted to Opera and cant surf without it.....
prankie is offline   Reply With Quote
Old 31-03-2006, 06:11 PM   #2 (permalink)
It appears that you may have a corrupted installer... Try downloading the installation files from a different mirror and running it... Also, clear your temp folder.. Make sure you run the installer with admin priviledges...
Arun
sakumar79 is offline   Reply With Quote
Old 01-04-2006, 11:36 AM   #3 (permalink)
D PrankMaster
prankie's Avatar
No, ia m not using .msi installer....
i cleared the temp folder, then tried installing,
but the same error is coming!!!
Old 03-04-2006, 06:07 PM   #4 (permalink)
JGuru's Avatar
Looks like a virus attacking Opera software!!
I suggest , that you format your harddisk
and reinstall Windows , and install Opera.
JGuru is offline   Reply With Quote
Old 03-04-2006, 06:12 PM   #5 (permalink)
gooby pls
Third Eye's Avatar
Corrupted Setup.
Download opera 9 from www.opera.com
Third Eye is online now   Reply With Quote
Old 03-04-2006, 07:43 PM   #6 (permalink)
Well then try the msi installer should solve your problem.
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline   Reply With Quote
Old 03-04-2006, 08:38 PM   #7 (permalink)
D PrankMaster
prankie's Avatar
No the setup was not corrupt!!! i had previously installd frm it...
I was fed up with the problem, so i reinstallled the OS. and now opera is working fine....
Old 23-07-2010, 12:22 PM   #8 (permalink)
Default Re: Problem installing opera!!!!
I tried to install Opera and Firefox. In both cases its says "file corrupt". What Shuld I do?
loginss is offline   Reply With Quote
