Old 23-03-2006, 11:37 AM   #1 (permalink)
Default installation
hi there,
when i try to install something it says installation file must be corrupt. Does it refer to windows installer? How can I deal with this. Plz help
Trinity is offline
Old 23-03-2006, 11:01 PM   #2 (permalink)
nach p's Avatar
Do you face same prob. with any particular software or any general or any particular windows inbuilt soft.
If u r facing problem with all soft package u r PC is infected which is corrupting your files.
Just do Virus and spy scan.
nach p is offline
Old 24-03-2006, 07:11 AM   #3 (permalink)
its only sometimes, not particular or specific exe. I was able to install quite a few other s/w though
Trinity is offline
Old 24-03-2006, 05:01 PM   #4 (permalink)
nach p's Avatar
Scan your whole system to find any infection in your system which may have corrupted u r files.
If scanning doesnt help then try to reinstall (fresh)your OS.
Take backup of any imp. data before doing fresh installation on that drive where you will install OS.
nach p is offline
Old 24-03-2006, 10:33 PM   #5 (permalink)
Are those softwares downloaded from the internet? If so, try downloading again.
Try installing software in digit cd or dvd.
Dumbledore is offline
