Old 09-03-2006, 11:07 AM   #1 (permalink)
Default pc booting again n again
pls help me guys
tomorrow i cleaned my room & pc ,after all that when i started my pc it just shows intel start screen & again start booting !!!
wats this problem is???
can any1 help????
gycapri is offline
Old 09-03-2006, 11:19 AM   #2 (permalink)
go to bios setting and just save n reboot this will solve ur prob
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 09-03-2006, 03:50 PM   #3 (permalink)
can u pls tell wat do u mean by "save"
pls help
gycapri is offline
Old 09-03-2006, 05:58 PM   #4 (permalink)
Default Hey Dude
he means go to bios n exit saving changes.
hitman_never_dies is offline
Old 09-03-2006, 08:23 PM   #5 (permalink)
::vicky::'s Avatar
did u seated ur ram properly
::vicky:: is offline
Old 10-03-2006, 02:18 PM   #6 (permalink)
can any1 make me clear y i do save n then exit if im not changing any setting ,if i have to change any setting then pls tell that ,wats going to change if i just opened bios n again i just exit by saving !!!
gycapri is offline
Old 10-03-2006, 02:24 PM   #7 (permalink)
gycapri is offline
Old 10-03-2006, 07:52 PM   #8 (permalink)
At what stage is it rebooting? Does it restart immediately after the intel start screen? Go into BIOS settings and disable the logo at bootup and you will get the details of BIOS booting... Might have some information there...
Also, if you opened your PC for cleaning, open it again to check if all cables are connected properly, RAM is seated properly, etc... Also, if you start the computer with case open, you might (in some cases only) see something that could help identify the problem...
Is there any beep sound when booting? If yes, check the number of beeps and sequence of long and short beeps. Along with the BIOS manufacturer info, it is possible to find what the beeps mean and rectify...
Arun
sakumar79 is offline
Old 10-03-2006, 10:40 PM   #9 (permalink)
Default Re: pc booting again n again
Originally Posted by gycapri
pls help me guys
can any1 help????
What you mean? Did it start day after tomorrow?
It seems by way of cleaning, so much dust and dirt entered inside the pc. Try to clean the pc interiors carefully.
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 11-03-2006, 03:16 AM   #10 (permalink)
::vicky::'s Avatar
sir did u overclocked ur system
Old 11-03-2006, 09:09 AM   #11 (permalink)
the prob is with ur ram or processor...........
one of the thing u have not inserted properly........
please take out those things again and then insert them properly..............
and then try.............
dharmeshhtailor is offline
