| Forum |
#1 (permalink) |
[/img]Although the CD has the mentioned file...the same kind of error continues for many a files... Plz help me in solvin the prob n installin IIS... |
#2 (permalink) |
Dude the i386 is a directory and it will be avail.And in that directory u don't have that dll file.....
#3 (permalink) | |
Bitten by the open-source bug... |
#6 (permalink) |
@suave_guy
Thnx pal..I tried to solve the prob given in the link but the last step could not b done...It said that xpsp2 is not a recognized internal or external command...wat do I do now?
#8 (permalink) | |
in my case it was WindowsXP-KB835935-SP2-ENU.exe
i generally prefer quality over quantity 1 aadi + 1 aadi = 1 full |
#9 (permalink) |
@aadipa
Sry pal bt my prob could not b solved even wen I changed the command to WindowsXP-KB835935-SP2-ENU /integrate:c:\winxp My WinXP SP2 is an inbuilt one I mean i did not instal the SP2 seperately after installing the WinXP.. What to do now?
#12 (permalink) |
>:)I-):(|)8-X
Did you try manually locating the file using the browse button?
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
