| Forum |
#1 (permalink) |
#2 (permalink) |
GUNNING DOWN TEAMS
First check ur registry and defragement ur drive, run scan disk and check for errors.....if u cannot do this....use s/w like norton system works and run appropriate tool to check ur OS....and HDD.....other option is
U can back up ur data by using backup s/w, if u have a DVD writer or enough disk space or can get a extra disk to trnasfer the data do it.....format ur HDD drive and reload teh OS.... then transfer the data...and ur done.....
The moment U stop learning ......u stop improving |
#4 (permalink) |
this prob usually come up when the hdd has bad sectors i suggest
first try to backup ur data on other hdd then perform a zero fill or low level format from Disk Manager or if u r not able to to backup the data run the surface scan of the whole hdd in dos mode boot with win98 in dos mode then run this command scandisk /all /autofix /surface |
#5 (permalink) |
If you have bad sectors then scandisk in 98 will get hanged and maybe sometimes DOS mode fails to fix Bad Sectors.
So first of all do scandisk from XP.It will fix all Bad sectors on c: drive (drive which u r choosing0 If there are no bad sectors then just do virus scan. U can also use software HDD Regenerator to fix bad sectors. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
