Old 02-03-2006, 12:45 PM   #1 (permalink)
God of Mistakes...
Garbage's Avatar
Default Problem of IE 7.0 Beta 2
Recently I installed IE 7.0 Beta 2. But when installed, my computer reboots & after rebooting it didn't go next to Welcome window.
Is it problem of XP Sp2 or of IE 7.0 Beta 2
Plz Reply.
Garbage is offline
Old 02-03-2006, 12:59 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
what exactlly happend?? at least this information is not enough to describe ur problem... pls post kore details... what do u mean by
pls describe the problem...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 02-03-2006, 01:09 PM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
it only goes upto welcome screen & hangs up.
Garbage is offline
Old 02-03-2006, 01:57 PM   #4 (permalink)
Better restore ur system.IE7 makes these problem(dude to bugs).My friend also has like this problem....
devarajan is offline
Old 02-03-2006, 03:18 PM   #5 (permalink)
while booting press F8, and then select LAST KNOWN GOOD CONFIGURATION.... hope this helps
Shwetanshu Srivastava
shwetanshu is offline
Old 02-03-2006, 10:34 PM   #6 (permalink)
God of Mistakes...
Garbage's Avatar
I open task manager( that opens) & click on New Task---> Brows & select rstrui from windows-->system32-->restore
Then I restore the system. Thanks god I had created a restore point before installing IE 7.0
But can anyone explain why this problem comes?
Garbage is offline
Old 02-03-2006, 10:53 PM   #7 (permalink)
Shock_the_Rock
Posts: n/a
Default Re: Problem of IE 7.0 Beta 2
R u using pirated copy of windows.if u r using then forget IE7
Old 05-03-2006, 06:20 AM   #8 (permalink)
Live The Dream!
agnels's Avatar
You are probably using a pirated copy of windows and also dont have the latest updates for your system. IE 7 requires genuine validation. I have legal windows copy and IE7 haven't given me a problem with any website till date.
agnels is offline
Old 05-03-2006, 10:19 AM   #9 (permalink)
Plz Reply.
Try to follow the tutorial in
http://www.thinkdigit.com/forum/viewtopic.php?t=28161
And it works 100% for me.....
