Old 01-03-2006, 05:37 PM   #1 (permalink)
Shock_the_Rock
Posts: n/a
Default Help me Digit ?
I have win xp pro with serivice 2 installed on my pc.
My problem is my pc won't restart/turnoff.i have to turn it off by ejecting the turnoff/restart button.How can i solve my problem.I off many services and turn unwanted services.
Tell me plz.
Old 01-03-2006, 06:36 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
wats ur OS and how old is ur HDD
vijay_7287 is offline
Old 01-03-2006, 07:01 PM   #3 (permalink)
pedal to metal
suave_guy's Avatar
start your computer in safe mode and see if you can restart/turnoff you computer from that mode
if we can than we need to check services or startup items in msconfig
so checkout safe mode and let us know...
ENjoy...
your "attitude" is your best friend...
suave_guy is offline
Old 01-03-2006, 07:23 PM   #4 (permalink)
Shock_the_Rock
Posts: n/a
Default hello smarty guy
it didn't turn off/restart in safe mode.
Old 01-03-2006, 07:38 PM   #5 (permalink)
pedal to metal
suave_guy's Avatar
create a new user account and see if you can turnoff/restart your computer from there....
see if you can atleast log off from your computer
if not than click on "log off", then click on "switch user" and from the login screen click on "turn off computer"
if in case you have norton installed on your system than you can type "services.msc" from run and from the services list there disable "symantec password validation" and see if that works...
ENjoy...
