Old 01-03-2006, 11:30 AM   #1 (permalink)
himtuna's Avatar
Default Help urgent winXP installation
I inserted the winXp bootable CD
and restarted the computer
but computer didn't boot from cd
then i manaully started the installation from My computer
then
computer booted from CD
installation started and I wanted to install a fresh copy of winXP
but couldn't formatt the existing partition
It gives message something winXP installation files or ehatever it is
I want to formatt my drive
then install winXP
I have done this many times
but this is not happening this time
nor i got the message press any key boot from cd
http://www.himtuna.com/
http://www.himanshuthakur.com/
Do good to be good !
himtuna is offline
Old 01-03-2006, 01:48 PM   #2 (permalink)
restart the pc and keep pressing delete button, then bios screen will appear , In the bios change the first boot up device to CDROM,then save the settings and exit the bios
from this u can start the fresh installation of XP and u r asked to format before installation , format the C drive
signature??? Let Me Think About It!!!
paul_007 is offline
Old 01-03-2006, 02:51 PM   #3 (permalink)
Chk out that u have right cd orelse follow the paul_007 step's.....
devarajan is offline
Old 01-03-2006, 08:22 PM   #4 (permalink)
himtuna's Avatar
I press F8 to enter the boot settings
Advanced options > boot settings
Nothing such like boot from cd-rom
I have a laptop.
himtuna is offline
Old 01-03-2006, 08:25 PM   #5 (permalink)
himtuna's Avatar
The message I get is
When I delete the c:\ drive
Setup is unable to perform the requested operation the selected partition. This parition contain temporary files that are required to complete installation.
himtuna is offline
Old 02-03-2006, 04:56 AM   #6 (permalink)
u wont have an option saying boot frm CD...
instead look for an option like... (( in BIOS ))
1st boot device..>
2nd Boot device...>
3rd Boot Device ... >
because u have to make CD ROM as boot device and then start the installation....go thru every option/menu/submeneu in BIOS...u'll find the option!
grinning_devil is offline
Old 02-03-2006, 11:43 AM   #7 (permalink)
hafees's Avatar
The problem is your temperory installation files for windows is saved in the same partition that u want to delete. (If you have an original Windows XP boot CD this wont happen).
Now the easiest way is to delete the partion using some third party tools like Pqmagic.
hafees is offline
Old 05-03-2006, 01:55 PM   #8 (permalink)
himtuna's Avatar
What I didn't had the bootable CD.
But a new problem............
I have written a new bootable CD and reinstalled the winXP and formatted everything I want
But the windows gives an error that original files have been replaced insert the winXp cd in the Drive
I have created the bootable Cd using nLite and installed all the post-servicepack updates.
Do I have to reinstall windows from same cd(integreted postupdates) or the original xp cd will work.
himtuna is offline
Old 05-03-2006, 02:56 PM   #9 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
tht depends on the files tht have been replaced
in most cases the old CD should work
coz the files copied are mostly frm the i386 folder
vijay_7287 is offline
Old 05-03-2006, 07:30 PM   #10 (permalink)
Try creating a bootable original XP cd without service pack. You can get the boot file from microsoft.com, and write a new cd with the boot file in nero along with old XP cd contents.
Yesterday - Dead
Today - Dying
Tomorrow - Never dies
The day after tomorrow - Where will you be !
Sreekanth V is offline
Old 05-03-2006, 07:52 PM   #11 (permalink)
Use the cd which u have used during the installation time.And other cd won't work.
