Hi to all,
I need to convert the .dat (Movie files) to .avi using Dr. Divx.
So i need some suggestion...i searched through the forum but did not got the req info...
generally a movie contains 2 cds (.dat)
i need to compress this to avi so that i can fit to a single cd with a good quality video.
1. What shold be the setting for Dr Divx.
2. Which Compressing Codec should i use.
3. wht should be the birate ....and so on...all the technicall settings...
Is there anybody using Dr Divx in this forum who can guide me..
Also i what to convert the movie DVD to a single Avi file of about 700MB
Please guide me... Thanks..
Regards,
Alive Hunter
