Old 28-10-2004, 11:01 AM   #1 (permalink)
Default Anyone who knows to speed up XP Pro
I am in bad shape and so is my PC.
After installing the Norton 2005(activated over net) my system has slown dows anyone got a idea to speed up other than changing FS. Itried it Its a failure.
shakti4evercool is offline
Old 28-10-2004, 11:09 AM   #2 (permalink)
try changing the virtual memory
ishaan is offline
Old 28-10-2004, 11:23 AM   #3 (permalink)
ice
How much ram do yu have??
ice
ice is offline
Old 30-10-2004, 12:56 AM   #4 (permalink)
You don't have to keep Auto Protect on at all times. Disable it when you use a processor hungry program.
Defrag your hard disk and increase your virtual memory or the size of your swap file, as our friend has suggested above.
Start MSConfig by pressing WinKey + R, typing MSConfig and pressing enter. Check to see if any unwanted services load during startup, and if so, disable them.
If you're really in trouble, disable the GUI effects in XP and use the classic theme.
DJ Shaji is offline
Old 30-10-2004, 06:10 AM   #5 (permalink)
sidewinder's Avatar
install more ram or uninstall nav
sidewinder is offline
Old 03-11-2004, 09:28 PM   #6 (permalink)
try switching off display effects and increase ur page file size. the best thing to do would be to uninstall NAV
Prakhar Agrawal
http://www.consumersofindia.com/inc/...ers/468_60.gif
I am a small man with big dreams.
prakhar_agrawal is offline
Old 03-11-2004, 09:29 PM   #7 (permalink)
Bewitched!
xenkatesh's Avatar
UNISTALL NAV this suck all the memory!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 04-11-2004, 08:32 AM   #8 (permalink)
try something like mcafee. it worked 4 me
deepakuma is offline
Old 04-11-2004, 02:03 PM   #9 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
You should try this link
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 04-11-2004, 03:05 PM   #10 (permalink)
Another Brick in the Wall
drgrudge's Avatar
do see the 30 minutes expert booklet given by digit some months ago to see some tweaks to speed up winxp
drgrudge is offline
