Old 07-02-2006, 05:58 PM   #1 (permalink)
Default DISPLAY PROBLEMS
Hi whenever i move my pointer over the battery icon in the taskbar the charge remaining is shown behind the taskbar.what can i do to make it appear in the foreground?
ravitejap is offline
Old 07-02-2006, 09:26 PM   #2 (permalink)
-- frm control panel disable the power options
-- is the taskbar locked ???? if yes then unlock it
-- right click on taskbar and click on "lock the taskbar ",that will unlock it
-- enable the power options
-- and then enable "lock the taskbar" .. this will lock it once again
lets see if these work out!
grinning_devil is offline
